WTT: Earthquake Pa-2075c
Ge_off_me
Parts Express Specialist
I want to trade my Earthquake Pa-2075c for a nice trunk mount EQ. Old school PPI and Phoenix Gold get priority.
Here are the specs:
Earthquake PA2075c
-THD@rated specs 0.015
-stable to 2ohms bridged
-A-wtd signal to noise ratio 105dB
-overload/thermal/DC/short protection
-built in 2-way electronic crossover
-HP and LP outputs
-9wx2 3/4hx11d
104 watts per channel at 4 ohms
160 watts per channel at 2 ohms (Stereo)
400 watts into 1 channel when bridged
I had a PA2300 running at 1ohm bridged and the only issue was it melted the plastic cover on the power/ground connections. I can only provide real world numbers on the PA4020C, which is a 20 x 4 according to Earthquake, it pumps out 60 watts at 12volts and 76 watts at 14volts. Bridged into a 4ohm load 220 watts. Impressive to say the least, Earthquake had their shiit together in the mid 90's and this model is a high current amp with a power supply twice as strong as it needs to be for a 4 ohm load. The PA2075C has three times the output than the PA4020C so multiply the numbers and you get an idea of what this amp can do...
GLWS
GLWS
Hmmmm You heard the man =] Looking for an eq guys.
Ge_off_me
Ge_off_me
Enon, Ohio
Ge_off_me
