Wtt: Aq2200
nate56
1. Product:
AQ 2200
2. Specs:
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage 14.4V
4 ohm power @ 12V @ 1% THD 500x 1
1 ohm power 2200 x 1
1 ohm power @ 16V 2500 x 1
2 ohm Linked power @ 14.4V @ 1% THD 4400 x 1
Dimensions 17.71"(L)x9.27"(W)x2.35"(H)
3. Description/Condition:
looks 8/10, working 10/10
4. What you are looking for: :
Same power @ 2ohms
View attachment 26538770View attachment 26538771View attachment 26538772
nate56
nate56
colorado
Madman11
