WTT Alpine SPX-17REF 6.5 Components
thisistiny
Graphic Designer
1. Product:
Alpine SPX-17REF
2. Specs:
6-1/2" Type X Series Component System
* Power Handling:
o Peak: 450 watts per set / 225 watts each side
o RMS: 150 watts per set / 75 watts each side
* Cross-rib aluminum cone
* (NBR) Nitrile Butadiene Rubber surround
* 1" Dome tweeter
* Cast aluminum frame
* Multiple crossover tuning options with minimum phase shift
* 4 ohms impedance
* Thermal transfer crossover chassis design
* Heat sink resistors
* Heavy gauge air core inductors
* Metalized poly capacitors
* 4-Level tweeter adjustment
* Tweeter protection
* Gold plated insert with tab
* Secure one-snap cover
3. Description/Condition:
About 3 months old.
Everything is in very good condition except for one of the tweeter. (one of the wire needs soldering as you can see in the pictures)
I do have the original box it came in. But not the foam packaging.
4. What you are looking for: :
Mainly looking for Audioque AQ1200d
or
Sundown SAZ-1500d
+ will add cash on my end if needed
5. Pictures of your item for trade:
The tweeter that needs soldering:
how are these compared to your crecendo's?
I like the crescendo's alot. I used to own alpine SPR-17s. And figured by getting a type X it would be even better. But no. These have to be bi-amp'd for the full capability. and i was just not having it. Just not into the whole bi-amp. im much more happy with the crescendo right now. happy with the passive crossover that comes with it too. haha.
But from the manual i was reading for the SPX-17REF, there is ALOT of option for placement of the speakers. If your REALLY REALLY into the SQ set up in your vehicle, this is your comps!
thisistiny
Graphic Designer
thisistiny
Las Vegas, NV
thisistiny
vegang
vegang
