Want a Sundown 3000, audiopipe 30001d, gp3000 pro or equivalant
in the NC area u must pickup
Porter Cable CPLC7060V
135 PSI, 60 Gal. Oil Lube Stationary Air Compressor
* 7 Peak HP, 3.0 HP Running
* 84 Dba
* 135 PSI - 77 gallon equivalent tank size as compared to conventional 125 PSI models
* Pump contains automotive style pistons, rings, and connecting rod
* Single stage, oil lubricated pump designed with aluminum body and head for best cooling and cast iron cylinder sleeves for best wear
* Large tank pressure gauge for easy visibility and better accuracy
* 240 Volt capacitor start induction motor with manual thermal overload protection
* Full-size belt guard
* 60 gallon air tank supports heavy duty, intermittent/continuous multi-tool usage
* Patented automatic belt tensioning system
* 84 Dba
