WTT: 15" Brahma MK1 for Pair of 10's
BASS_WARRIOR
Formerly HATCHET_WARRIOR
Just like the title says, I'm looking to trade my Brahma for a pair of 10's.
Need to be d4 and 500-600w RMS. They will be ran off the sub channel of my big belle at 1ohm.
I would really like a pair of SE's or something similar, I'll add cash if need be. I would consider 8's as well.
The Sub is in good shape other then a small mark on the surround. It does not go all the way through and does not effect performance.
yes sir. Jake says around .5cu ft each for ported. The guy I bought them from (A friend of jake) stated 1.4 cu ft tunned to 33 hz with 15sq in of port area scored a 137.xx (Im pretty sure it was a 137) on 2 E8's in a TC with subs up port back.
Sorry, 2.4 cu ft //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Re = 3.37 ohms (4 ohm nominal)
Fs = 34.9 hz
Qes = 0.5323
Qms = 6.93
Qts = 0.4943
Vas = 7.6 L
BL = 13.3 N/A
Mms = 127.7 grams
Cms = 162 um/N
Xmax = 12mm one-way linear (70% BL method)
Rated RMS Power = 200 watts
Depth = 4.25"
OD w/ gasket = 8 5/16"
Cut Out = 7"
Sealed Box:
0.280 ft^3 w/ F3 of 50 Hz (Qtc = 0.707)
Ported Box:
0.60 ft^3 tuned to 30 Hz
F3 of 25 Hz
BASS_WARRIOR
BASS_WARRIOR
H-town
BASS_WARRIOR
