A3
# RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
# Mode : AB
# Number of channels : 2
# Output power in 4 ohm : 2 x 150 watt
# Output power in 2 ohm : 2 x 270 Watt
# Output power in 1 ohm : 2 x 425 Watt
# Output power in 4 ohm bridge mode : 550 Watt
# Output power in 2 ohm bridge mode : 870 Watt
# Output power in 1 ohm bridge mode : 1200 watt
# S / N ratio, A-weighted : > 100 dB
# Damping factor : > 200
# Input impedance : > 10 kohm
# Input sensitivity, variable : 0,2 - 7 V
# Filter, highpass, variable : 20 - 200 Hz
# Filter lowpass, variable : 50-125 Hz
# Terminal for external cooling fan : Yes
# Double DC-inputs : Yes
# Phase shift button : Yes
# Current draw, idle : 1,1 A
# Current draw, maximum : 140 A
A5
* RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
* Mode : AB
* Number of channels : 3
* Output power in 4 ohm : 2 x 85 W
* Output power in 2 ohm : 2 x 100 W
* Mono channel, ouput power in 4 ohm : 300 W
* Mono channel, output power in 2 ohm : 500 W
* Mono channel, output power in 1 ohm : 780 W
* S / N ratio, A-weighted : > 100 dB
* Damping factor : > 200
* Input impedance : > 10 kohm
* Input sensitivity, variable : 0,2 - 7 V
* Filter, front channels : Highpass: 50-125 Hz
* Filter, mono channel : Lowpass: 40-90 Hz. Subsonic: 25 Hz
* Phase shift control 0-180 degr. : Yes
* Remote sub level control with phase control : Yes
* Terminal for external cooling fan : Yes
* Dual DC-inputs : No
* Current draw, idle : 0,5 A
* Current draw, maximum : 90 A
* Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
