wtt 15 for small amp
thegreatestpenn
lazy genius
I DO NOT WANT TO ADD CASH!! I got a 15" Ample audio acwd dual4ohm sub in a trade with fasfocus00, but I don't plan on making a box for it anytime soon and would rather have a small mono or 2channel instead right now. So if you want a 15" and have an amp laying around lets trade. will sell outright, but would rather just trade.
condition is good on the sub, has a repaired puncture in the surround.
I have two Jensen old school amps that are around 6" X 6"
One is rated at 40x2
the other is 44x2
I also have a lil bigger jensen amp prob around 8" x 6" (300 Watt)
I have two Jensen old school amps that are around 6" X 6"One is rated at 40x2
the other is 44x2
shoot me pix of the bigger one and specs if you have them. would you give up 2 of those jensens for the 15?
90 shipped if this is small enough its an autotek at1000 bnib warranty ect....:
Amplifier Class: Class A/B
Number of Channels: 2-Channel
Maximum Power: 1000 Watts
RMS Power Output @ 4 Ohms : 125 Watts x 2-Channel
RMS Power Output @ 2 Ohms : 250 Watts x 2-Channel
Bridged Power: 500 Watts x 1-Channel
THD: 0.05%
Signal-to-Noise Ratio (dB) : 95dB
Frequency Response (Hz) : 30Hz~1.2kHz
Built-in Crossover: Yes
High-Pass Crossover Frequency: 60Hz~1.2kHz
Low-Pass Crossover Frequency: 20Hz~250Hz
Bass Boost: 0dB~12dB
Bass Remote: N/A
Fan Cooled: N/A
Fuse Rating: 30A x 2
Dimensions (Width x Height x Length) Inches: 10.03" x 2.04" x 9.85"
ok ill ask some customers what they may have. if i still had the little 2 channel kw i would give it to you for shipping cost lolz i gave it to a friend instead lolz. it was only 6 x 8 and does rated 40x2 easily.
thegreatestpenn
lazy genius
thegreatestpenn
columbus
thegreatestpenn
Mike Mccabe
