Wtf New Alternatpr Doesnt Work!!!!!!!
Geminidj2000
The Bad Luck Kid
OMG firs the brakes....now we put in a new alternator and nothing changed light still dim at idle even with lights off its a 150a amp alternator in a 1989 legend and my system is onlt running 500 rms power whats wrong with my car!!!!!!!!!!!!!!! do u guys think that my distribution blok or amps are taking powewr when not on? cause this is gay i drained my deep cycle and standard battery
Originally posted by Geminidj2000 OMG firs the brakes....now we put in a new alternator and nothing changed light still dim at idle even with lights off its a 150a amp alternator in a 1989 legend and my system is onlt running 500 rms power whats wrong with my car!!!!!!!!!!!!!!! do u guys think that my distribution blok or amps are taking powewr when not on? cause this is gay i drained my deep cycle and standard battery
Did you upgrade your charge wire and ground wires from the engine to the battery ??
on my car that isnt really possible because thers a plug that u plug in................. my friend said that it looks like my alternator belt is going slow so were gonna pry 9it out and try it tomorow
Originally posted by Geminidj2000 on my car that isnt really possible because thers a plug that u plug in................. my friend said that it looks like my alternator belt is going slow so were gonna pry 9it out and try it tomorow
Ok so you have the stock 10/12 Gauge ? Wire running from your alternator to your battery and then you have ??? 4 gauge running to your amps ??
Originally posted by Geminidj2000 yes except i have 2 guage going to my amps
You really need to upgrade your alt wire and ground wires , If you dont have the power getting to your batteries the alt was a waste ! If the charge wire is to little it will melt . Make a new plug or whatever you have to do but make a bigger charge wire and ground wire . Does the alt have a positive lug post that a nut goes on for the charge wire ? Most alternators have this and also a plastic plug that plugs in which is not normally the charge wire but the turn on leads for the alt .
12 gauge charge wire and 150 amp alternator >>>>>>>>
Geminidj2000
The Bad Luck Kid
Geminidj2000
Denver
Spddracer
