WTB/WTTF Stout 2 or 4 channel
Yes, but it isn't able to be bridged at 2 ohms......only 4. Hence my problem there.
From the website:
Rated power is 125 watts x 4 into 4 ohm or 200w x 4 into 2 ohm
Bridged power is 250w x 2 into 8 ohm or 400w x 2 into 4 ohm.
I could do the 250x2 into 8 ohm, but still need 500 watts per side....lol.
Those are the old specs for the draconia II he does not make anymore. I just talked to Stephen and he says the new Draconia III does 450wx2 @ 4 ohms. he does not have these amps on his website yet, we however just put them up on ours. He also came out with a new minotaur.
ZED Draconia-III - Vertex Audio
Avionixx axt1200.2 using in car right now..clearing out what i dont need...similar to crystal and elemental designs ED..underrated power..should produce about 1500@4ohm..$175 shipped
NUMBER OF CHANNELS 2 Power rated @12.5v
RMS Power @ 4 Ohm,
RMS Power @ 2 Ohm,
RMS Power @ Bridged 4 Ohm,
Variable Frequency Bass EQ 25Hz - 80Hz
Variable Dynamic Bass Boost 0 - 18dB
Variable Low Pass Crossover Filter 50Hz - 400Hz 24dB
Variable High Pass Crossover Filter 50Hz - 400Hz 24dB
Line Outputs Yes
Overload Protection Yes
Power Bandwidth (Rated Power -1dB) 15Hz - 30kHz
Short Circuit Protection Yes
Cross-Wire Protection Yes
DC Off-Set Protection Yes
Thermal Protection Yes
Variable Input Level 15OmV - 6V
Heat Sink Dimensions- Inches 13 7/8 X 9 7/8 X 2 1/4
Hey GVP, I'll pass on the Avionixx. I need something that is rock solid reliable. Like you said, they were run under ED, and not the best rep for reliability.
Vertex, I am still looking.....might have a line on a DD amp that may work....checking on the lead now.
mojo1 - sorry, but that is too under ratd for my needs. I prefer to have headroom in an amp. Thanks for the offer though.
CHEMMINS
CHEMMINS
Nevernever Land
CHEMMINS
