Wtb/wtt good 10 or 12 inch sub
I have a 10'' Rockford Fosgate T1 10'' with a custom Recone with a new larger 1k RMS voice coil and larger cone... Has a bigger cone area hardened cone. will also throw in the old cone... it is fully intact so you can put/ build a new recone if you want the original rubber surround. I personally dont like rubber because in compromises sound response and clarity. here is a link:
Rockford Fosgate T1 10'' Dual 2 Ohm Subwoofer
Hello I have:
2: T1D412 12" Power T1 4-Ohm DVC Subwoofer
CEA-2031 Compliant: CEA-2031 Guidelines
Nominal Impedance: Dual 4-Ohm
Power Handling (Watts RMS): 800 Watts RMS
1600 Watts MAX
Voice Coil Diameter: 3" (75.4 mm)
Magnet Weight (oz): 123 oz. (3.48 kg)
Speaker Connector: Compression Terminal
Fs (Hz): 29.2
Re (Ohms): 6.50
Le (mH): 2.4
Qms: 4.50
Qes: 0.71
Qts: 0.61
Vas (Liters): 55.8
Sd (cm2): 548
SPL (dB @ 1w/1m): 85
Xmax (mm): 16
Woofer Displacement (in): 0.106 cu.ft. (3.0 Liters)
Cutout Diameter (in): 11.25 in. (28.57 cm)
Mounting Depth (in): 6.75 in. (17.15 cm)
Shipping Weight: 33.3 Lbs. (15.10 Kg.)
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
496
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
  • Locked
I can get this to somewhere in NJ in US. Is that possible for you to ship that out ?
Papabiz
Papabiz
Great bend ks
ROLO
slater
    May 2, 2024
slater
    May 2, 2024
