wtb sound deadner
damp pro is also double the cost so do the math:)
id rather pay more and do less work than do more work for less money.
i work hard and in the sun all day, its my money ill spend it how i please //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i want something with more thickness ie damplifier pro to where i only need to lay down one layer instead of raamat which ill have to lay down two to equal the damp pro
I appreciate the compliment, but please keep in mind that thickness is not an accurate measurement of how good a product is nore how good a value it is.
For example:
Damplifier
1.25 mm thick
.45 lbs per sq. ft.
Many other mats on the market are 1.5 mm thick and only weight .35 lbs per sq ft. And have only 2 mils of foil.
Second Skin Damplifier weighs more even though it is thinner.
This is because there is less oxygen content int he butyl and more resin content as well.
It is difficult to extrapolate performance value when compaing weight but it is easier to see that you get more butyl even though it is thinner.
If we did not defoam the mixture while it was blending, and if we left the mixer on for a few extra hours and allowed more air to be pushed in to the product we could easily double the volume of the butyl, but it would weigh the same.
So 2 products, side by side, one would be twice as thick, but would be just as heavy. Doenst mean that the thicker one is any better...
Thickness is a decent guide to go by but not accurate in determining value/performance
If we are talking math:
1. How is Damplifier Pro double the cost? Perhaps I am rusty but I do not see double the cost.
2. You get nearly twice as much adhesive content with Damplifier Pro and 3 times as much foil.
Your comparison is like trying to convince someone to purchase a honda rather than a BMW becuase Honda is cheaper and since they both have 4 wheels, there is no difference between the ride.
ANT
http://www.damplifier.com
No thats not a good comparison LOL. cuz raamat is basically same and way cheaper. EVEn if u need 2 layers even 1 will do the same as second skin. but whatever he wants he should get i was just stating my opinion as well as you were its all good:)
Look. I like Rick
He sells a good product and is a great guy. The product works well and is a good value for what you get ut to same that raamm, but is basically the same is absolutely false. If youare going to draw comparison between 2 products, at least present some facts to back up your claims.
Raammat BXT
.35 lbs psf
2 mils foil
300 degree heat rating
Damplifier Pro
.65 lbs psf
6 mils foil
500 degree heat rating
So when you do the math, it works out like this
Raammat bxt
100 sq feet = 35 lbs
Damplifier Pro
100 sq feet = 65 lbs
So you get almost twice as much material and 3 times as much foil in the same sq footage.
I am all for raammat. In fact, I send Rick a few customers per week. I just want people to know the difference between anacdotal opinons and honest specs.
Ok so say you use 50sq ft (or 100 w/e ) of RAAmat and 100sq ft of damplifer pro in your trunk would you notice the diff? i honestly doubt it, the only diference you would notice is in your bank account when purchasing second skin its a good product dont get me wrong just a little pricey.
tc3k101
Ω
tc3k101
Socal
kovemaster559
