WTB: Small 2 channel amp
Image Hosting at TurboImageHost.com
240SE 400SE 600SE
Rated Power @ 14.4 V (0.1 % THD): 2 x 60 Watts 2 x 100 Watts 2 x 150 Watts
4 Ohm Stereo
Rated Power @ 14.4 V (0.1 % THD): 2 x 120 Watts 2 x 200 Watts 2 x 300 Watts
2 Ohm Stereo
Rated Power @ 14.4 V (0.2 % THD): 1 x 240 Watts 1 x 400 Watts 1 x 600 Watts
4 Ohm Mono
Frequency Response: 20 –20,000 Hz 20 –20,000 Hz 20 –20,000 Hz
+/- 0.5 dB +/- 0.5 dB +/- 0.5 dB
Input Sensitivity: 0.1 – 5 V 0.1 – 5 V 0.1 – 5 V
S/N Ratio @ rated power: 100 dB 100 dB 100 dB
High-Pass Filter Crossover Frequency: 30 - 300 Hz 30 - 300 Hz 30 - 300 Hz
(Continuously Variable, @18 dB/Oct.)
Low-Pass Filter Crossover Frequency: 30 - 300 Hz 30 - 300 Hz 30 - 300 Hz
Bass Boost Level: 0 - 18 dB @ 45 Hz 0 - 18 dB @ 45 Hz 0 - 18 dB @ 45 Hz
Dimensions: 11" W (280 mm) 11" W (280 mm) 11" W (280 mm)
2 3/8" H (60 mm) 2 3/8" H (60 mm) 2 3/8" H (60 mm)
8 1/2" L (215 mm) 13 3/16 L (335 mm) 15 1/2 L (395 mm)
SPEAKER IMPEDANCE
Although extremely low impedance speaker loads will not damage the amplifier, for stereo mode,
we recommend speaker loads of 2, 4 or 8 ohms; for bridged mono mode, 4 or 8 ohms. (Note: In
bridged mono mode, the amplifier sees only half of the speaker impedance.)
NOTE remember that we are not defying the laws of Physics! IF you decide to connect ANY
Coustic amplifier into a bridged mono load BELOW 4 ohms, Physics dictates that current draw
doubles! This is not too big a problem with the 240SE or 400SE. But with the 600SE this is
DANGEROUS. The current draw could be as great as 200 amps (peak). Make sure you wire
your system properly.
With the 600SE we recommend ONLY a 4 gauge wire OR larger
http://www.coustic.com/support/pdfs/Coustic240.400.600.SEManual.pdf
basscort2009
Banned
basscort2009
dallas tx
Tallc
