WTB rca noise filter
Xprime4
****in' canadian
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif i never tough i would ask for that since my instal are always top notch //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
this time around, the sub amp is making noise into the whole system, can't stand it and nothing worked as far as fixing this
so i need a bandaid. Quality noise filter that won'T affect the system performance if possible.
i know few of you guys should have them. if not tell me where i can get one that's not too bad
usually called a ground loop isolator
ya that's what I thought. I get alt whine at lower rpms....well when first taking off....I've re dne my ground 3 times. sometime this month I plan to just run a wire from the negative on the front battery to the trunk as my ground. im hoping this will fix it? if u got any other ideas please pm me and let me know...
which one did you use? I have tried like 3 with no prevail
You may have another issue then!!! I've used a bunch of these before...they CAN indeed work!
Nah, not a good idea to do that bro. You want your ground as short as possible and having a 16-17ft ground isn't exactly "as short as possible"!!!//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
V.
Xprime4
****in' canadian
Xprime4
Quebec, Canada
mokedaddy
vegang
vegang
