IDK how, but my Extremis 6.4's are laughing at the one I have now and it benched at 1000 RMS... thats 250 RMS per extremis? So I'll run 2 per amp bridged and keep the gains down. Then I'll hopefully have the headroom I thought I would have with just one.
4 ohm specs are:
Fs: 37 Hz,
Qms: 3.3,
Qes: 0.36,
Qts: 0.31,
Vas: 27 liters,
Re: 3.5 Ohms,
Le: 0.11 mH;
BL: 6.7 N/A,
Sd: 140 cm^2,
Cms: 1 mm/N,
Mms: 19 grams,
Xmax 13mm on way.
4 ohm specs are:
Fs: 37 Hz,
Qms: 3.3,
Qes: 0.36,
Qts: 0.31,
Vas: 27 liters,
Re: 3.5 Ohms,
Le: 0.11 mH;
BL: 6.7 N/A,
Sd: 140 cm^2,
Cms: 1 mm/N,
Mms: 19 grams,
Xmax 13mm on way.
