wtb:high output alt
yea its got the mazda motor otherwise itld be a lil easier to find ne for stock location..... ill make somethin work tho , ill even take externally regulated if i can get one i justh need something to keep up with the 500.1 and the highs amps.....
that still tells us nothing about what motor it is...
i have one that will fit the ford duratech 3l
a stock from a 5.3l GM motor
and a CS144 case alt.
which one would you like?
gotcha //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
might i suggest the CS144 case alt. its a beast of an alt, BNIB, and cheap!! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I can get you a 320 amp for 1200 Its freaking huge its an ambulance alternator no crappy little body one. Leece Neville Is the make of it I can get external regulated versions of it tell me how you want it FREAKING HUGE If you want something smaller tell me what king of case 200 amp ones in a large gm case will be the most common ones. But they will put out what they are rated this guys shop never let me down. Also may get a stock replacement for you that will put out more just tell me the motor you have Ill check for core availability tomorrow
You can get a Olds Aurora replacement alternator online for about 125 that puts out 140 Amps. Just installed a rebuilt delco into my Aurora and things are good...
But for a 500.1, I think may want something abit bigger, but $125 for 140 amps aint a bad deal.
200 at idle 320 at 2000 rpm caterpillar/ freightliner replacement part You can not get an alternator in a small case that will put that out If you get it it will be a ***** to make it fit and you will have to find your own pulley. I know there is 2 320s and 1 270 sitting on the shelf right now.
1200...lol...na theres enough others around.... hoss yours id really have to see about mounting up im more lookin for regular style lookin alts not 4.6/5.4 ....lol.. thanks tho... but well see if i can find a used one to mount up to try i should just have az drop one off to play with...lol.... theyre good for somethin here and there... all i know is one style fits the ps pump spot one fits oem.... otherwise yours may fit where the ac was...lol...
yunvme666
Fah-Q!!!
yunvme666
boston ,ny
yunvme666
