WTB Good amp, Good components
kenbei
I am looking for a deal on a good amp (i.e. sundown, arc, zapco, brax, etc) that will power a pair of components with at least 125wx2 but prefer more in the 200wx2 range (4 ohm)
I am also looking for a good pair of components. Rainbow profi vanadium, dls iridium, focal k2p etc. Something along those lines.
Thanks
I've got two Zapcos.. make me an offer for both.. perfect for an active setup //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Zapco MODEL Z100S2
2 x 50w rms
Specs:
Power/Mode
130 watts @ 4 ohm Stereo .02% THD
190 watts @ 2 ohm Stereo .04% THD
190 watts @ 4 ohm Mono .04% THD
Frequency Response 20-20kHz
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 40 V/uS
Damping Factor 300 @ 4 ohms
Input Sensitivity .25-2.5 volts
Power Requirements 22amps, max, @ 2 ohm
Fuse Internal, 30A
Minimum Load 2ohms Nominal Stereo, 4 ohms nominal mono
Idle Current .8A
Dimensions 10.25"x6"x2.25"
Zapco MODEL Z150S2
2 x 75w rms
Specs:
160 watts @ 4 ohm Stereo .02% THD
250 watts @ 2 ohm Stereo .005% THD
250 watts @ 4 ohm Mono .04% THD
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 50 V/uS
Fuse Internal, 20A
Idle Current .85A
Dimensions 11.625"x6"x2.25"
I know you needed more power.. but if you had both you could have a great SQ setup by running active.. Zapco Z100S2 for the tweets and Zapco Z150S2 for the mids..
I was going to use these in my new car.. so if I don't sell them within the next month or two they are going in my new car when I trade in //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Im selling my Focals K2P 6.5. They wud only fir if I cut the doors on my 2000 BMW 328. And they've been sitting in my closet since. I decided to go with the Slim models that Focal offers. Here's ur chance. The Speakers were not fully installed ( realized that they didnt fit when we were putting the door panel back in place. Reason being that in that car the speakers screw on to the door panel and not the door itself. I also have an Eclipse 33230 that was not used in the process and is virtually "brand new" with out any exajuration.
Focal K2 Power 165KF 80 RMS 160 Peak
Eclipse 2 channel 33230 130x2 RMS @4 ohms
200x2 RMS @ 2 ohms
I paid $199 for the amp and $369 for the Components. Make me a REASONABLE offer.
I've copy and pasted this info in other threads looking for the same. Im just looking to sell them and dont wanna keep typing the same over and over. Thamks for understanding.
kenbei
kenbei
Rochester MN
TWiZTiD859
BP1Fanatic
BP1Fanatic
