WTB good 100x4channel amp...
n8te81
Was looking for a good 4channel that was at least 100x4 but not over 150x4. Its going in my 350z so i need it to be decent SQ but on a budget price for now.Was just seeing if anyone had anything laying around that would fit the bill or had any suggestions. Thx
How is the SQ on it?? I have my DD comps so i need something pretty clean going to them...I didnt see a THD rating on that link so I was just wondering.
same build house as arc audio man
•Black Box Series 4-Channel Class A/B Car Amplifier
•RMS Power Rating: ◦4 ohms: 110 watts x 4 chan.
◦2 ohms: 175 watts x 4 chan.
◦Bridged, 4 ohms: 350 watts x 2 chan.
•Max power output: 1400 watts
•Pulse Width Modulated MOSFET power supply
•LED power (blue) and protect (flashing blue) indicators
•Piano black finish
•End caps with illuminated blackbox logo
•Stereo, mono and tri-mode operation
•Variable Bass Boost (0 to +15 dB bass boost at 50 Hz)
•Soft Start Turn-on
•4/3/2 channel operation
•Speaker-level inputs with signal sensing for automatic turn-on
•3-Way Microprocessor System Protection circuitry (thermal, overload, and speaker short protection)
•Heavy duty aluminum alloy heatsink for extreme heat dissipation
•Silver-plated RCA level inputs
•Silver-plated screw terminals
•Input sensitivity: ◦Level: 200mV-8V
•10x Frequency multiplier
•Variable high-pass filter (55-3,300 Hz, 24 dB/octave)
•Variable low-pass filter (55-3,300 Hz, 24 dB/octave)
•Frequency response: 10-50,000 Hz
•Dimensions: 8-13/16"L x 22-13/16"W x 2-1/4"H
•8-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Specification BlackBox stereo 2
RMS Power @ 13.8v DC
Power @ 4 Ohms stereo 2 x 100 WRMS
Power @ 2 Ohms stereo 2 x 125 WRMS
Power @ 4 Ohms bridged 1 x 250 WRMS
Minimum speaker impendence 2 Ohm stereo / 4 Ohm bridged
THD Distortion 0.1%
IMD Distortion 0.1%
Frequency Response 7Hz - 38 KHz
Input Sensitivity 250 mV - 5V
Input Impendence 15K
Signal to Noise Ratio 96 dB
Channel Separation -61 dB
Crossover Network
Low pass filter 30 Hz – 300 Hz
Bass Boost 0 dB - +24 Db
High pass filter 50 Hz – 1KHz
Fuse rating 15A x 2
Size length x width x height 348mm x 224mm x 57 mm
BlackBox stereo 4
4 x 100 WRMS
4 x 125 WRMS
2 x 250 WRMS
0.1%
0.1%
5Hz - 43 KHz
250 mV - 5V
15K
88 dB
-57 dB
30 Hz – 300 Hz
0 dB - +24 Db
50 Hz – 1KHz
30A x 2
448mm x 224mm x 57 mm
I have an mint infinity 475a
specs:
•4-channel car amplifier
•75 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
•180 watts RMS x 2 at 4 ohms in bridged mode
•CEA-2006 compliant
•variable high- and low-pass filters (32-320 Hz, 12 dB/octave)
•variable bass boost (0-6 dB at 50 Hz)
•Class-AB amplifier design
•MOSFET power supply
•preamp-level inputs and outputs
•fuse rating: 35A x 2
•4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
•14-3/4"W x 2-11/16"H x 9"D
I have JL audio 300/4 v2 250 shipped
Let me know if anything shoot me a pm.
n8te81
n8te81
Amarillo,tx
n8te81
