WTB Fiberglass Kit or Stuff to build a fiberglass enclosure
ummm all you need to do is buy resin , hardener and whatever cloth you want to use ... wether fleece or fiberglass
also some kind of filler bondo, a putty or whatever you feel like using
This info is so wrong on so many different levels.
Join http://www.fiberglassforums.com and search for supply links and stickies.
And you don't have enough money yet.
so you dont even need accual fiberglass..you just coat the fleece in resin, then spread hardener on it then a layer of bondo then sand it down and paint it??
build a skeleton of the area i want glassed with peaks and reinforcment for the look i want, i like to use fleece to get the shape , resin that 50 grit grind then fiberglass mesh more resin and repeat, grind then duraglass in spots need, evercoat rage to even out the surface , 80 then 150 from there, prime , drysand , seal (if needed) base , then clearcoat
build a skeleton of the area i want glassed with peaks and reinforcment for the look i want, i like to use fleece to get the shape , resin that 50 grit grind then fiberglass mesh, grind then duraglass in spots need, evercoat rage to even out the surface , 80 then 150 from there, prime , drysand , seal (if needed) base , then clearcoat
Now look at the difference in those 2 quotes.
The 1st one is quite vague and if you followed what it said, you would end up with some nasty stuff.
While fleece is a decent mold material, Ponte' is better.
Here is a comparision.... http://www.fiberglassforums.com/showthread.php?t=1850
As for the mention of putty and a filler, you said Bondo. As I am sure you are aware since you work in a body shop, Bondo is a name brand and a brand that SUCKS.
You mentioned in the 2nd quote that you use Rage. Excellent choice.
As you know, the Rage alone is $40 a gallon, fiberglass mat is $20 or so for enough to do a sub box. Resin is $30ish a gallon and you need approximatly 2 gallons depending on the enclosure size.
Now you need sand paper, wood, primer and paint or carpet.
Here is a link that has some commonly used supplies..... http://www.fiberglassforums.com/showthread.php?t=7044
As you may see, you need to be a member to view, but we have some of the most instructive and informative stickies and people willing to help you out.
IbSlamn
IbSlamn
Alabama
wgsj_fortvalley
