Wtb: Dei Xk07
XK07 and many of the express kits have been replaced by the FLCAN, and PK-series modules. PKALL only supports Maxima up to 03, you need a DLPK. The XK modules require firmware flashes to work, the PK modules do not. Prices should be similar, but I assure you, the DLPK is gonna be much easier to install and use.
So the XK07 is cheaper, will work, but needs firmware flash, the pkall is newer, more $, and doesn't require flash..
basically? Just trying to weigh my options, I'm pretty fluent I guess you could say with computers, flashing things is not an issue
Both are around $50, most cases, but you're dead on other than that. A quick Google search, and it appears the average price of the DLPK is lower than that of the XK07, which makes it a hands-down better bet.
Ty very much sir. The DLPK will be compatible with a python 881xp ?
whitem1ke88
.. BUILD IN PROGRESS ..
whitem1ke88
Broward, FL
whitem1ke88
AJ (ACE)
    Jun 28, 2026
