WTB: component set
tee
You know
BR
I'm in the market to buy a set of components for my front stage. It has to take at least 100W, preferably around 150W.
For trades, I have a BNIB 12" Kicker L5 06 version. Also have Pioneer Rev 6.5 components. Lastly, I also have a Garmin nuvi 360 portable navigation system.
I see a bunch of people selling subs, amps, batts, everything. Everything except for comps.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I got a set of Audiopipe ATS-612N 6.5" components, they take 175rms/350peak, they do get loud, but im going with a new set of memphis Mclass 6.5" comps, so im selling these, they have 1hr of play time, bought them from R/T Pimp he is a authorized audiopipe dealer, and they come with a full warranty!!! $50shipped!! Pics if you want!!
im selling a set of AD audio components u just have to ship in the one mid 2 them because it's fcked. but everything is under warranty still . hmmm maybe we could work out a trade for that garmin pics of it?
Hi there i got Kicker 6.5 ss comp here some pics
http://i156.photobucket.com/albums/t...6/DSCN0257.jpg
http://i156.photobucket.com/albums/t...6/DSCN0258.jpg
http://i156.photobucket.com/albums/t...6/DSCN0261.jpg
the black stuff was for the vibration's
I've got a set of cdt M6 midbasses with drt-26a tweets. You'd need to run active or pick up some passive crossovers. They'll definately take the 150w or more though, check the forsale thread in my sig if interested
OK did have now it works sorry the black stuff was for the vibration's
Features:
o SS-Series 6-1/2" Component Speaker System
o Pair of SS Midrange Drivers
o Two oversized Tetoron-domed SS30 Tweeters
o Two Grilles
o Crossover Network
* Crossover
o System optimized two-way asymmetrical passive crossover network
o 23dB high pass and 12 dB low pass @ 2.8kHz
o Air core inductors
o Mylar film filter capacitors
o 3 position tweeter attenuator (0dB, +1.5dB, +3.0dB tweeter output level)
o Zobel impedance compensation
* Tweeter
o DuPont Tetoron (soft dome) 30mm Dia. Tweeter
o Ferro-fluid cooled voice coil
o Dual neo magnets in tweeter
o Vented inner motor system
o Sealed and tuned tweeter enclosure
o Foam dispersion and control plug
o Copper clad aluminum voice coil
o Flush, Angle, Surface Mounting
* Midrange
o Tri-Tech cone with Rohm Rohacell foam
o T-Cut top plate with Micro Plate copper cap
o Edgewound copper clad aluminum ribbon voice coil
o Balanced coil construction
o Variable surround thickness
o Z-Wave spider design
* SPECIFICATIONS
o 400 Watts Peak
o 180 Watts RMS
o Frequency Response : 40Hz - 22kHz
o Crossover Point : 2.8kHz
o Crossover Slope : 24 hi/12 lo (dB/oct)
o Sensitivity : 87dB 1W/1M
* Midrange
o Outside Diameter : 6-7/16"
o Mounting Hole : 5-7/16"
o Mounting Depth : 2-13/16"
* Tweeter
o Outside Diameter : 2-5/16"
o Mounting Hole : 1-15/16"
o Mounting Depth : 1-1/8"
* Crossover
o Outside Diameter : 5-5/8"
tee
You know
tee
BR
mikey7182
