WTB Broken old school high end amps!!!!
xtant 603x
Specs :
3 channel amplifier
2 x 75W + 1 x 150W at 4 ohms
2 x 150W + 1 x 300W at 2 ohms
1 x 300W bridge at 4 ohms
Fuse: External 100A
Xtant 121m
Specs:
Watts per Channel @ 4 Ohms: 1 x 125 Watts 2 x 50 Watts 4 x 50 Watts
Watts per Channel @ 2 Ohms: 1 x 250 Watts 2 x 100 Watts 4 x 100 Watts
Bridged Mono Output @ 4 Ohms: N/A 1 x 200 Watts 2 x 200 Watts
Frequency Response: 5 Hz to 50 kHz 5 Hz to 50 kHz 5 Hz to 50kHz
Distortion (THD):
Signal-To-Noise Ratio: > 100 dB > 100 dB > 100 dB
Damping Factor (@ 100 Hz into 4½ load): > 200 > 200 > 200
Inpt Sensitivity
Unbalanced Source 100mV to 8.5V 100mV to 8.5V 100mV to 8.5V
Balanced Source 100mV to 17V 100mV to 17V 100mV to 17V
Output Impedance: 2 - 8 Ohms 2 - 8 Ohms 2 - 8 Ohms
Output Impedance (Bridged): 4 - 8 Ohms 4 - 8 Ohms 4 - 8 Ohms
Supply Voltage: 10.5 to 15 Volts 10.5 to 15 Volts 10.5 to 15 Volts
Fuse: 30 Amp 30 Amp 50 Amp
Both amps power up but produce no sound. No visible damage to inside as far as my eye can see. Price I am willing to neg. Physical conditon is good on both some minor scratches mostly on the bottom but they still shine like new.
orion 250 with a bad channel other works so i hve been told ... A1200 ppi art black series works fine ?
Is the Orion 250 an Xtr or Hcca? And I have a few old Art Series PPI's right now, so Id only be interested in the functional a1200 if it was SUPER cheap.
Thanks,
DD
xtant 603x Specs :
3 channel amplifier
Fuse: External 100A
Xtant 121m
Specs:
Distortion (THD):
Inpt Sensitivity
Im going to have to pass on these. They just dont hold any value in the used market, and Id probably end up being upside down in them after repairs.
Thanks,
DD
No used value?? These are the essence of sq and quality. Maybe joe jack doesn’t know there value but anyone with any knowledge of tru car audio would love to have these.
I hear you man, but the market is the market...
An xtant 603x just sold for $129.50 on ebay.
Thanks,
DD
Thanks,
DD
diver_dylan
diver_dylan
The Big Sleazy
diver_dylan
Mike Mccabe
