i need 2 battery posts for my stinger battery, i would like to find one that i can put a normal battery cable clamp on and then a screw in the top if at all possible
humm i think that is the same size as mine...would you be able to get a pic of your posts?and i see what your sayin and i think it will work!Hello B/I just threaded a Metric Bolt into the threads of the Post.The bolt went in quite aways.The Bolt hex head is 8/mm.I know it doesn't help w/thread size.Do you think that you could use them if you found a metric rod or bolt,and cut what you needed,screw it into the post,than into the Battery threads?
It just may work.If you consider doin' that,and feel it would work for you w/o issues...I'll give you them.No trying to get you to ghetto rig your battery,it's jus' something that came to mind.Just pay S&H to me.The shaft of the posts have a *Knurled Pattern* in them that I'd assume it's to hold the Standard terminal on better.
You need two of them? LMK,if you're interested.Jus' trying to help you out you going/:crazy:...lol.
Regards/
Raymond
lol its ok, i sent you a message backHello Brandon/Sent you an *E/Mail*.../.
Regards/
Raymond
PS:I think I used the wrong name for you...Sorry.Brain Fart.
*******************^^^^^^^^^^^^^^^*******************lol its ok, i sent you a message back
