wtb battery posts
i need 2 battery posts for my stinger battery, i would like to find one that i can put a normal battery cable clamp on and then a screw in the top if at all possible
hey bro! haha go to autozone! buy there generic terminal. its works great! you can fabricate your own buss bar if needed!
they work great and there 6 bux each
Hello SPL/
Do you have a Pic of what they are? I may have a pair,but not sure if it's what you need.Are they for Top Mount or Side Mount?
Do the posts Screw in to the Battery?
I don't know is why I'm asking.Jus' trying to help ifd I can/;O].Take Care.
Regards/
Raymond
*************************^^^^^^^^^^************************Hello SPL/
Regards/
Raymond
the ones i need screw into the top, this is a pic of a battery like mine and the original posts
http://www.krystal-ice.co.uk/acatalog/sp800.jpg
Morning/
I just looked at the 4/Gold plated ones I have.They are *Female* type.They don't have the Bolt on the bottom to screw into to Battery.They have threads inside each one,and would assume they're Metric threads.I have two Male and two Female that are stamped on the top of each post.I They are all new in the baggies I got them in.I bought them for an older hook up but never used them.
Sorry I couldn't help you out....
Regards/
Raymond
Morning/I just looked at the 4/Gold plated ones I have.They are *Female* type.They don't have the Bolt on the bottom to screw into to Battery.They have threads inside each one,and would assume they're Metric threads.I have two Male and two Female that are stamped on the top of each post.I They are all new in the baggies I got them in.I bought them for an older hook up but never used them.
Regards/
Raymond
****...thank for the help any ways
Hello B/
I just threaded a Metric Bolt into the threads of the Post.The bolt went in quite aways.The Bolt hex head is 8/mm.I know it doesn't help w/thread size.Do you think that you could use them if you found a metric rod or bolt,and cut what you needed,screw it into the post,than into the Battery threads?
It just may work.If you consider doin' that,and feel it would work for you w/o issues...I'll give you them.No trying to get you to ghetto rig your battery,it's jus' something that came to mind.Just pay S&H to me.The shaft of the posts have a *Knurled Pattern* in them that I'd assume it's to hold the Standard terminal on better.
You need two of them? LMK,if you're interested.Jus' trying to help you out you going/:crazy:...lol.
Regards/
Raymond
SPL-Master
SPL-Master
Portland OR
MustangGT25YRS
