Looking for the following:
Xtant X604 or JL 300/4
and
Xtant x1001 or JL 1000/1
If you have something you that you think is a good equivalent to these, I am open to look at it, but I kind of got out of the car audio game around 2001-2002 and all of the above were pretty much the best at that time (arguably of course depending on preference).
I would like it to be in good shape and fully functioning, not looking to fix anything or send out for service. I will be running the amps off the stock electrical system with an upgraded battery and two 4-ga. runs w/ 100A breakers. I had an X604 and X1001 back in '02, so I have all the wiring left from it. I need amps that will be able to get the job done off of this power, so efficiency is very important. Will most likely be using four 12" subs, nothing extravagant, maybe some JL 12W3's. I appreciate the input stage of both the JL and Xtant in that they are quite compatible with stock radios for signal, but will perferably be using an aftermarket unit. However, I am in process of finding a new car, so this is really up in the air b/c of stock nav systems, built-in controls, etc.
Thanks for your time,
Ryan
and
Ryan
