I have a lightly used DLS A3 amp for sale
Specs:
http://www.dls.se/en/car/prod.html?produkt=en_6
ULTIMATE series A3 is a powerful two-channel amplifier. A true, dual mono block with separate power sources that provides power output of 2 x 150 Watts with 4 ohm stereo and 550/870 Watts with 4/2 ohm mono. The amplifier is 1 ohm stable.
Built-in fan control. Built-in, variable 50-125 Hz switchable low-pass filter for subwoofers. Built-in variable 20-200 Hz. high-pass filter that can be used as a subsonic filter or high-pass filter for front systems. Dual power terminals where you can connect dual power feeds or a DLS Power Cap. Button for switching phases when you use it as a subwoofer amplifier.
This is a true high end SQ amp at a very reasonable price
Asking $375 OBO plus shiping including original box and owners manual.
phiber-optik@shaw.ca
Specs:
