why 2 ohms? did you already buy d2 subs?Looking for an amp that puts out about 1000watts rms at 2 ohms. Budget: $150 (audiopipe, Hifonics Brutus, etc)
its the same thing, 1000w at 1 ohm is the same as 1000w at 2 ohms. only difference is youll probably spend more finding a 1000@2 than 1000@1I figure I'd rather run them at 2ohms than 1ohm
Doesn't running the amp at a 1ohm load make it "work harder" and get hot?its the same thing, 1000w at 1 ohm is the same as 1000w at 2 ohms. only difference is youll probably spend more finding a 1000@2 than 1000@1
it does if the amp is designed to run at 2, but 1000w will be 1000w and (x) amount of amperage pull regardless if its at 1,2,3,4,5 ANY ohm load. it is the same thing.Doesn't running the amp at a 1ohm load make it "work harder" and get hot?
yes well some.are audiopipe amps stable at 1ohm?
you really cant up buget? what subs you planning on getting? an amp is probably something id try to get wuality of becasue the amp is what has the ability to fry your subs and well thats not good.Was looking at the audiopipe APMI-1500
I'm getting a pair of Sundown SD-10syou really cant up buget? what subs you planning on getting? an amp is probably something id try to get wuality of becasue the amp is what has the ability to fry your subs and well thats not good.
How do I go about not using all 1800 watts if my subs are wired to 1ohm?http://www.caraudio.com/forums/amplifier-classifieds/616611-us-amps-md2d-fs%5Ctrade.html
nice amp and quality, plus headroom is always a good thing. just becasue teh amp does 1800 doesnt mean you have to use them
