WTB amp for sub 450-650 @ 4ohms
JoshC
The Taco MASTA
As title states need an amp for my JBL p1022. 500-700rms @ 4 would be perfect.
When first powered up, my memphis wont receive signal until u pop top of its case. Steve at Ampmedics has recently worked on it, has no idea what the problem is. Will do parcial trade if u think u can fix/use it. Model's in sig
Other wise looking to spend about 150shipped
look on ebay for an alpine mrp m1000 think they do 600 at 4 ohms, but there usually under rated by 100-200 watts so prob around 700 rms at 4 ohms and i think you can get them f0r 150 shipped on fleebay.
---------- Post added at 01:12 PM ---------- Previous post was at 01:12 PM ----------
used of coarse.
I have the Zed Audio made USA US Acoustics 2150 SeriesII up for grabbs,and it is very clean and will do nicely at the 4ohm mono load within the classifieds?? $130.00 shipped.I had it pushing a 1000rms dvc 2ohm 10,and had it at close to 1'clock and pounded nicely!!!!I have the original specs pamphlet that I can make you a copy of the info as well..Specs as followed:
@4ohms-150x2
@2ohms-250x2
@4ohms Mono/Bridged-500x1
All ratings are @12.9v
THD-0.01%
Noise below rated output-107DB
Idle current0.9a
Fuse rating-35a
Size-L=15.7in/W=6.3in/H=1.9
Weight=8.0lbs
I currently have two of these amps,I had a total of 4 at one time..1 on each sub,and sounded quite Rich
Pm me and let me know???Thanks
JoshC
The Taco MASTA
JoshC
Houston, tx
audiobaun
