WTB amp 1200+WRMS
Would like more in the 2000WRMS range but I am open if the right deal comes and they can be strapped(well maybe not)
I will be buying in the next day or less so lets here them
2 Kicker SX1250.1 amps strapped = 2700 RMS @ 2 ohms. Brand new from anywhere online is over a grand, I'll do it for around $700 and throw in the SXRC for them.
  • 625 watts RMS x 1 at 2 ohms
  • 1250 watts RMS x 1 at 1 ohm
  • 1-ohm stable
  • keypad menu control
  • variable low-pass crossover (30-200 Hz) with adjustable slope (choose from 6, 12, 18, 24, 30, 36, 42, and 48 dB/octave)
  • variable subsonic filter (10-60 Hz) with adjustable slope (choose from 6, 12, 18, and 24 dB/octave)
  • Digital KickEQ single band parametric equalizer with variable center frequency and variable Q
  • Wired Bass Remote included
  • Kompressor expansion/compression circuitry with four settings: Off, Contour, Attack, and Redline
  • 4 memory banks store intricate EQ cut/boost, low-pass crossover, phase, bass boost, sub-sonic filter, and compression settings
  • Sick Bay technology for real-time diagnostics and troubleshooting (includes pink noise generator)
  • preamp outputs
  • UltraMatch gain control for optimal input level matching
  • amp strapping circuit lets you connect a second SX1250.1 amp for double the power output
  • cooling fan
  • 22-1/2"W x 2-1/2"H x 10"D (17-1/2"W without endcaps)
I can have an actual pic up tomorrow if you want one, but it looks just like this:
http://www.sonicelectronix.com/pictures.php?id=1500
It comes with all the stuff pictured
I have two, neither has ever seen power, one is a factory refurb and is rated 1280 @ 1 ohm, the other is brand new and is rated 1420 @ 1 ohm.
Let me know if you're interested
I'm not real sure how they are at lower ohms, I haven't used them yet. But I think it would be okay at impedances a little under 1 if you had the right electrical set up and set the gains correctly. But I don't know for sure. PM me if you're seriously interested. Thanks
zero hero
zero hero
Ontario
KK07
AJ (ACE)
    Jun 28, 2026
