I'm buying a dual 2 ohm Re xxx 15. I'm looking to run around 2000 rms to it. I am in need of a cheap amp. I spend most of the money on the sub and Rebuild the box for my sub as well as a front and rear stage to compensate. I also need a 4 ch amp but looking to buy a monoblock amp stable at 1 ohm to run true clean power anywhere from 2 to 3K rms. I know these subs are known to take 8K+ but I am using this as a daily driver and I want this for long term so... I was considering using a Z1 as many of you may know from my last thread but, I don't know if I want to run that much power into the sub everyday. Even at 4 ohms it is been bench tested in real world testing to run just under 2 thousand watts from a site I happen to just find. The amp will run that sub and run it well and then I could use the amp when I felt like going and competing I could just wire the box down to 1 ohm but even then I just want to be able to run it like a regular set up. Plus I don't want to have to run more wire thru the truck than is already there.( 2 strands of 1/0 awg from front to back and 4 sets of 12 awg wire for my Voice stages as well as 2 sets of 12 awg for the sub as well as 2 sets of RCA's and the remote wires. So if you have an amp sitting around your wanting to get rid of that is capable of true clean power around 2 to 3 K rms under 400 shipped please let me know.!!! sry if you have messaged me before and I said no thanks I was going to go with that other amp when I was going to run an Atomic APX 12 but I have decided against it and went with something a little more musical. so any help is much appreciated:veryhapp:
