WTB 6.5" MDF speaker rings
One of my friends is a Mac user, he once told me about his dilemma, he bought a Panasonic SD3 camcorder and wanted to do some editings for a WMV HD demo presentation, this may probably be easily done by some ordinary MTS to WMV Converter software, but not the case with Mac.
It is known to all that WMV with the full name of Windows Media Video is a compressed video file format for several codecs developed by Microsoft. From which, we can't hardly draw a conclusion that WMV is supported by Windows Media Player natively. However, its compatibility with Mac system is not very satisfying, some commonly used Mac player like QuickTime may be unable to play it. What should he do, just wait and see if some miracle will happen to him?
But miracle really happens to him, what he need is to get a MTS to WMV Converter for Mac software, it is a wonderful and astonishing software which can convert you MTS video file to WMV format with quick speed and satisfactory quality, besides it has versatile and powerful editing capability which allows him to adjust the Brightness, Contrast, Saturation of the original file. He can also adjust aspect ratio to widescreen to 4:3 or 16:9, and tweak resolution, bite rate, frame rate, at your selection.
Another indispensable item combined to get his job done is to free down-load Windows Media Player 9 for Mac from Microsoft website, it is developed by Microsoft for Mac users to playback both local and streamed WMV files.
Tutorial
Step by step to convert MTS to WMV on Mac
Step 1: Download and install MTS to WMV Converter for Mac
The safe and easy way to download and install our software is to do it via our official website http://www.iOrgSoft.com. Then you can run a test. Any problem regarding this process will be welcomed to render to our dedicated service team, we are always at your service.
Step 2: Load file
Click Add File at the top of the main interface to browse your computer hard disk and to import the files to convert. You can import a bundle of files at one time.
Step 3: Select output format and the directory
In the drop-down list of Profile select wmv as the output format, then click click Browse beside Open button to browse your computer hard disk to specify the location to store the converted file.
Step 4: Crop video
Click Edit at the middle of the panel to pop up a Video Edit window, where there are three editing tabs available, you can do your editing by clicking the corresponding tab. For example, if you click Crop, you can crop the file in the following two ways:
Selecting aspect ration: You are allowed to select an output aspect ration from Zoom drop-down list. There are four choices available: Original, Full Screen, 16:9 and 4:3.
Setting the values: Type the value directly or set the value in Left, Right, Top and Bottom area to set the position of the cropping frame.
Step 5: Conversion
Click Convert button at the right lower panel to convert the file automatically. The time taking varies depending on your project.
How many? what's Outer Diameter? I can probably do those for you quick
I can take a hint ... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
hatedonmostly
throwin' hunnits, hunnits
hatedonmostly
Detroit, MI
joeybutts
