WTB: 400x4 @ 2 ohm 4 channel amp
200x4 @ 4 ohms?? yow! bump for your search though.
lol, just trying to power a lot of speakers with fewer amps.. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
any suggestions on any? doesn't have to be that much but just anything that'd give 8 mids at least 25 watts apiece i'd be happy with.
lanzar Vibe ?
# 4 x 150 Watts RMS @ 4 Ohms
# 4 x 300 Watts Max @ 4 Ohms
4 x 250 Watts @ 2 Ohms RMS
lanzar opti?
# 500 Watts x 2 RMS Power @ 4 Ohms
# 1000 Watts x 2 Max Power @ 4 Ohms
# 2000 Watts x 1 Max Power @ 4 Ohms Bridged
# 750 Watts x 2 Watts RMS Power @ 2 Ohms
# Electronic Crossover Network
# Bass Boost Circuit
# Bridgeable at 4 Ohms
# 2 Ohm Stereo Stable
# Double Sided Epoxy PCB Circuit Board
# Gold Plated RCA Inputs
# Line Outs for Left and Right Channels
# Low Pass Filter Controls
# High Pass Filter Controls
# Subwoofer Remote Level Control
# Power and Protection LED Indicators
# Soft Turn On/Off
# Minimum Speaker Impedance: 2 Ohms
# THD: 0.04%
# S/N Ratio: 100dB
# Channel Separation: 60dB
# Frequency Response: 10Hz - 35kHz
# Variable Low Pass Filter: 50Hz~120Hz, 24dB/Octave
# Variable High Pass Filter: 50Hz~750Hz, 24dB/Octave
# Variable Bass Boost: 0 to 18dB
# Input Sensitivity: 200mV ~ 8V
# Fuse Rating: 40A x 4
I've got a sherwood A250x2.
Does 250 x 2 @ 4 ohm, and I'd imagine it does close to what you are asking at 2 ohm. It's a Dual mono design.
Check it out on ROE. I'd let it go for 140 + shipping.
You're not gonna find that.
well,
Product MPN
MPN HK598
Key Features
Amplifier Type Multi Channels
Bridgable Bridgable
RMS Power at 4 Ohms 200 W x 4
RMS Power at 2 Ohms 400 W x 4
I found it, doubt it does that but like I said, looking for something similar to it.
JL Audio
ThugStep
JL Audio
KY
BLACKonBLACK98
