I'm confused as to how this will work, can anyone explain a bit better how a mono amp uses 2 terminals to wire up subs as if it were two seperate channels?
edit: let me clarify my question. so there are two sets of speaker terminals on the amp, and I have two subs both single 4ohm VC, wired independently of each other. If I take speaker wire from the + - of the 1st set of terminals on the amp to the first subwoofer, and the + - of the second set of terminals on the amp to the second subwoofer, this effectively represents a 2ohm load into a single channel to the amp, as if I were running two S4 subs in parallel? So basically I can run my two subs in parallel and not have any wires running between the two subs?
