WTB - 2 CH amp
looking for something decent for @ 100 bucks. needs to do at least 75 rms. the smaller the footprint the better, as i cant use anything real big.
I've got a powerbass ASA300.2 I'll sell for $50 + shipping. It's got a pretty small footprint. 7.8"L x 9.3"W x 1.9"H
It is a bit scraped on top because it was mounted under my seat, and part of the seat would scrape it when I'd move the chair. I can get pics for you if you want.
• 2 ohm Power : 150W x 2
• 4 ohm Mono Power : 300W x 1
• Peak Power : 600W
• Total Harmonic Distortion :
• Frequency Response : 20Hz - 22,000Hz
• S/N Ratio : >94 dB/W/M
• Damping Factor : >150
• Input Sensitivity : 0.5 - 4.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 40Hz - 250Hz
• Low-Pass Crossover Freq : 40Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 40Hz
• Dimensions : 7.8" x 9.3" x 1.9"
I can do $68 shipped.
keep the offers coming guys. thinkin bout that powerbass..........would like that us amps but it wont fit into the space that im looking to fit........seems to have a fairly large footprint
Yeah its fairly big.
Dimensions: 18.9" L x 11" W x 2.7" H
Oh well. Good luck finding and amp!
$120 shipped Have original box,manuals and bass knob
Number of Channels 2
Rated Power
continuous power 60W x 2 @ 4 Ohms RMS
125W x 2 @ 2-Ohms RMS
250W x 1 @ 4-Ohms bridged RMS
Total Power
total sum of 'rated power' 250 Watts
Bridgeable Yes
Crossover Controls High-Pass (HP): 40-400Hz 12dB/octave Butterworth
Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
Tone Controls Bass: 0dB to +18dB @ 45Hz
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Punch Bass EQ (included with cable)
Visual Indicators Power On
Signal Level
Thermal Status
Speaker Protection
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 0.5 dB
Shipping Weight 11.00 Lbs.
(4.9 Kg.)
Dimensions (HxWxL) 2.1 x 11 x 11.7 (in)
5.3 x 27.9 x 29.7 (cm)
Phoenix Gold XS2300 .....very small footprint....
75x2@4ohm
300x1@4ohm..
1ohm stable in stereo
2ohm stable bridged ......small little powerhouse amp...looks near new....using it right now on comps and it works fine.....old school US MADE Phoenix Gold and built like a little dynomite.......
$80 shipped
mihklo
mihklo
CHARLESTON, SC
mihklo
