WTB:100wRMSx2@4ohm AMP or 200wRMSx1@4ohm AMP
O.G. D-Wet
[]D [] []v[] []D
Looking for a small amp to beat my old Advent 10s. They're rated 50wRMS-160wMAX so I'm tryin to put 100RMS of clean power to each of them at 4ohm. Looking for something round .05% THD or lower @ 4ohmload. Looking at the PowerBass ASA-400.2, some UltraLinear amps and some other similar amplifiers. Looking for something with a very simple, clean, even old school look to it. Might even go for 75wRMS if I liek the amp. budget is $100 to cover the amp and shipping. DOESN'T HAVE TO BE PRETTY! This is just a little temporary beater system. It wont be too loud but it will def sound clean
Under-rated OS amps and Over-rated crap amps are also considered!!! Just as long as the SQ is shweeet
I only have one pic of it at the moment...
It's only rated at 25wpc, but I imagine that's underrated.
It is under 1% thd
I had little wire to work with off the adapter, so I spliced on some extra wire. I can provide a diagram of what color goes to what.
People seem real interested in this amp...I may just list it in the classifieds and see what I get for it.
-Dylan
It is under 1% thd
-Dylan
It's a cute lil bugger. Whats the deal on the other amps? they look pretty shweeet as well
I would love to sell you the Hifonics, but I may end up trading it with someone else. For its size, it is a powerhouse.
The Alpine, on the far left, is probably less power than you are looking for. It has a 15a fuse, so I would expect 150-200wrms.
If you agree with that power range, than I also have a Sony XM-3021 (good, old Sony). It has a 15a fuse as well, and like the Alphasonik, I would imagine it is conservatively rated at 30Wx2. It is .04% THD too...I have not tested it yet though, the only reason being that I don't have the wiring harness. I am on the search though...maybe even a wiring diagram would work, so I could solder in wires.
If you want bigger power, I have an old *** Sherwood amp from the early 80's. It main selling point was its durability, and it shows. It is a mess cosmetically, and when I took off the bottom plate, it looked like an absolute mess. I cleaned it up and hooked it up, and to my great surprise, it worked perfectly. It's probably not a sound quality amp, but I have heard that it is decent as far as most Sherwood stuff goes. I hooked it up with a 12v battery charger at home, and it seriously made my 18 APX move...although I'm sure that's more power than you need. Let me know if you're interested
O.G. D-Wet
[]D [] []v[] []D
O.G. D-Wet
Maple Shade, NJ
BloodyGuts335i
