WTB: 1000 Watt Mono Amplifier
what subs do you have and what voice coil configuration are they? and then how do you have them wired. that will tell ya what ohm load you'll be puttin on the amp.
I have dual Pioneer TS-W308D4
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Subwoofers/Champion/TS-W308D2|D4?tab=B
Watts MAX. Music Power 1400 Watts
Watts Nominal Power Handling 400 Watts
Frequency Response 20 ~ 180Hz
Sensitivity D2 (90dB) D4 (92dB)
Ohm Rating D2: (1 or 4 ohm) D4: (2 or 8 ohm)
So I am guessing.. I will be using a 2 or 8 ohm?
I haven't wired them up on the box yet, I am letting my friend do this..
Pioneer USA - TS-W308D2|D4 - 12" Champion Series Subwoofers with 1400 Watts Max. Power
You will need to make your power at 1ohm or 4ohm. They are dual 4 ohm voice coils. Wire all 4 in parallel to make 1ohm (all positive to positive, negative to negative). Wire each sub in series (positive from one coil to negative to the other), then wire both subs in parallel to make a 4ohm load. It'll be easier/cheaper to get your power at 1ohm most likely.
myG37
myG37
San Diego, California, United States
shiipseki
