would you feed a 12" rl-p 900 watts daily?
bonesninja
well i currently have an autotek mm1400.1=1400@1 ohm and i have 2 12" rl-p's d4 on the way and that would be roughly 500wrms daily off of one amp but i'm considering ordering a 2nd amp. they do 1000@2ohms so that would be between 750-900rms daily to each sub. Would you feel comfortable with that setup for a daily driver?
.......and before someone dumps....yes my electrical is MORE than capable of handling all 3 Autoteks.
just do the single amp, I doubt the gain in output(which wouldnt be that much) would be worth spending all the money on another amp
Oh, also look at the other thread you already made about this //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hmmmm...so you're saying that a 500-800watt increase in power would not be worth it? I find this a hard pill to swallow.
You said 700watts each off of one amp and then asked about giving it 900. Thats about a 30% power increase.... how much ouput you expect too gain, especially when you can get(or get dam close) full output out of em with 700 each.
actually i said 500 off of one amp, 1400 watts is rated, i'll never actually see that number daily........ and yes i expect to gain alot of output by increasing the power 50-80% per driver.........i simply asked if they could take it.
not to mention that by running the amps at 2 ohms, i'll be takin it easier oon it then if i run one amp at 1 ohm.
actually i said 500 off of one amp, 1400 watts is rated, i'll never actually see that number daily........ and yes i expect to gain alot of output by increasing the power 50-80% per driver.........i simply asked if they could take it.not to mention that by running the amps at 2 ohms, i'll be takin it easier oon it then if i run one amp at 1 ohm.
one is 700 each rated the other option is 1k each rated. That is less than a 50% increase. Where you coming up with 50-80 %? You wont see the full 700, nope...but you won't see the full 1k either //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
dude...you are dense. i never said they would see 1000 each i said from 500 watts each to 750-900 each
if you go from 500 each to 750-900 each that would be a 50-80% increase in power
i'm not trying to be a dick man....but don't you see my point? i said they would see roughly 500 off of one amp and 750-900 off of 2 amps...that is a 50-80% increase in power. i know hwta you are thinking as far as power compression but that certainly isn't going to apply to me in this instance....that would certainly apply if i was already running 2000 watts and was only going to gain 200 watts per sub, but when you talk 50-80% gains then YES the gain should be huge.
bonesninja
bonesninja
Lima, Ohio
bonesninja
