Would this amp blow out two DD Z's?
the z series is meant for 60hz+........................................................................................................
um.. because it is idiotic? that is a good reason.. but hey.. chicken has shown he already has no taste.. why not finish it off, right?
there using 2 of the 15ks one for each side 4 btls and mids and highs for the right side will go to one amp and 4 btls and mids and highs from left will go to the other
15,000 Watts RMS ????
Let me get this straight, they use the same Voice Coil as a 9500 series subwoofer and the 99Z is 15,000 Watts RMS ? How do you figure this ? Because it has a Neodymium Magnet Motor ? Because it has better cooling ? Because you don't know any better ??
The Digital Designs 9500 G with a Composite cone can handle more overall power than the DD99Z subwoofer. The DD99Z subwoofer has a higher BL product and does better numbers with the same relative power. 15,000 to 20,000 watts is where the subwoofer is maxed out at in the right enclosure with a frequency of around 58 to 60 hertz and up. Now, with around 10,000 to 15,000 watts of power in the right enclosure, the DD99Z will take the power a lot better than the 9500G because it has better cooling and dissipates heat better where as the 9500 holds a lot more heat in the magnetic gap. BUT, the 9500 can take more power overall on a burp then the 99Z. If you don't believe me, buy both of them and do the testing.
he's looking to turn heads and its working. taste or no taste its his choice, his money. $20g is like $20 to him. he doesnt care
please.. remove yourself from his sack. i dont care how much money he has:) money isnt an issue with me, either.. i just have taste:)
still retarded:)
because DEE DUH says so, and alan dante has done it!!!!!!//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
The DD99Z will take around 15,000 to 20,000 watts on a burp. It will NOT take 15,000 watts RMS period for any amount of time!! And FYI the Rockford Fosgate 15K amplifer puts out 15,000 Watts RMS for about 30 seconds. Then it has to be recharged. So, it is NOT a 15,000 watt RMS amplifier like you are implying.
A 9500 will take up to 30,000 watts on a burp in the right box in the right range. So, I guess it is also 15,000 watts rms ? Maybe even 30,000 watts rms ??
Gaussian
Gaussian
Bakersfield, CA
Louisiana_CRX
