Worst F*cking Amp settings I have ever seen in my life
wooo... the +32 dbz model is 650 for install... i can do +24.94 dbz for 500
If I send you all my amps, will you do discount? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
he wasn't running 30-50hz.The X/O was on FULL, AKA bypassed. he was running his subs full range boosted at 100hz.
No, he set the subsonic on @ 30 Hz. And freq cutoff was @ 50 Hz.
most likely set to full range those other settings weren't active
crossovers > you
Check your manual:
"By setting the selector to FULL RANGE, no crossover frequencies will affect the output."
30hz up boosted 12db @ 100hz.
Do you get it yet?
FULL = FULL PASS, over-riding the cutoff frequency.
Not that it matters. I just hate losing an arguement when it's clear I'm right //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Solid amp! I have the Z7000 50w@4ohm, 1500@1ohm. had it about 5yrs now @1ohm and it has yet to give me a problem.
mine is similar but is 50w @4 ohms and 1200@1ohm. nice cheater amps.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ahh i have seen those before but they arent listed in the cadence archives. probably about the same im guessing. probably a decent amp ya got there.
Looked s
turdy
Yay //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Do you get it yet?FULL = FULL PASS, over-riding the cutoff frequency.
There was no arguement //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Sneaky Cadence
Sho-nuff!
alil big/long though but hey I've run my amp all day and in the heat, I never had a problem with it.
Hopefully the OP's amp is working the way it's suppose too.
GL:)
GAM3OVR
Jeka is Back
GAM3OVR
Russia
GAM3OVR
