worked on the saturn all day yesterday *PICS*
req
am a mod.
most of it was little stuff, i re-ran all the wires under the seat rails and under the back seat, removed two RCA's i didnt need, i dicked around trying to figure out how im going to set things up, i taped up a portion of the trunk, i mounted my EQ's and stuff, i played with my glove compartment trying to figure out how its going to work, and i got my white trunklid on. i still need to carpet it tho //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
but i got a major step forward with my EQ rack.
its not done yet, but they are in where they will be staying. i need to make a c over for them, and for the mounting screws. you will see how that goes together.
heres a few pics i just shot of them. and the other horn (wich is temporarially installed with a few zipties until i figure out how the glove box will work. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
lots of stuff that still needs to be done. but its comming together.
rack from the outside (will be covered at a later date)
from the inside (again, not finished)
closer - look, its not done yet ****it. but its a **** cool idea //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
the ground for my amps (like on the front, conviently located on the rear drivers side strut mount)
and what you all have been waiting for - the passanger side horn //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
oh yea, there will be lots of SS spectrum on the rear deck, so dont fret!
oK! madukes is making me pancakes. so i gotta go. but leave some feedback when i get back //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
nice mount for the eqs. Since they are recessed into the metal they don't look like they are going to be visible... or are they?
care to get a shot of how you mounted the horn?
no need for tint, they will be hidden with a beauty panel //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks polecat. means alot commin from you //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
pwnt by pat: if you read the caption - it says its temporarially mounted with a few zipties to some points under the dash around the hornbody. i gotta figure out how the glovebox will work before i go and start screwing them in and stuff //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i need to find some 6" drawer rollers so i can make the glove box into a pull out thing, rather than a drop down thing.
lol good looking. i would order press feet like these http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-367 and stow the rear hinge idea. it will just make it harder to mess with unless you putem on actuators. just make the panel removable so you can get to them easy. after you get everything in then decide how you wanna improve/trick it out. with your glove box i would refab the dash part along the sides anyway you see fit with only reguards to being leaving 3/8" to make a cover around where the glove box fits into so all you will see is the drawer rails and cover up where the hindge used to be. looks good with good common sense behind it keep it up.
i think you will be in awe of what the horns will do though lol hang on to your jock strap. only weak part i see is location of the midbasses as i think it would hamper your stage depth from the front but we will see.
req
am a mod.
req
Syracuse, NY
req
