Wire Harness Diagram and Head Units Diagram help
Ok so I need some help with matching some of the wiring from my wire harness to my head unit. this is the code diagram from the ford right below.
NOTE: When black wire is not present. Ground radio to vehicle chasis. All colors may not be present on all leads due to manufacturers specifications.
Metra/Eia wiring Color code.
12 volt ignition/acc RED
12Volt batt/Memory YELLOW
Ground BLACK*
Power Antenna BLUE
Amp turn-on BLUE/WHITE
Amp Ground BLACK/WHITE
Illumination ORANGE
Dimmer ORANGE/WHITE
Power mute BROWN
Right front + Gray
Right front - Gray/black
Left front + White
Left front - White/Black
Right rear + Violet
Right rear -Violet/black
Left rear + green
Left rear - green/black
Here are the wire codes on the diagram for the head unit. which i'm not sure sure where to put these on the wire code above? I was told by a specialist that this cord will work but these last six aren't list on the above diagram. help please.
Key1,
key 2,
parking break
reverse gear
Permaneht 12 volts +
12v acc
Where do I match these?
Ground BLACK*
Power Antenna BLUE
Illumination ORANGE
Dimmer ORANGE/WHITE
Power mute BROWN
Right front + Gray
Left front + White
Right rear + Violet
Left rear + green
Key1,
key 2,
parking break
reverse gear
12v acc
Key1, --- probably not needed
key 2, ---probably not needed
parking break ---will need to go to ground or switch, depending on unit (I would try to ground first...) *SHOULD* be connected to parking brake switch so you cant watch video while driving
reverse gear - ---hook to reverse light, to trigger backup camera (if you dont have a backup camera, doesnt need to be connected)
Permaneht 12 volts + ---- goes to 12v battery/memory YELLOW
12v acc --- goes to 12v ign/acc RED
Unit can probably have a gps option, so they add it to outside chassis...
PainedEvolution
PainedEvolution
triangle,va
PainedEvolution
