Winners only.
By the way...here's the thread for full context 😁
Is this four outputs or two?
If I connect it to my battery, does it quadruple the output?
What if I bridge it?
And what I said was to a neophyte who was providing partial and/or inaccurate info about his amp.
What I said holds true as his amp was essentially low-grade stuff, and I think you said the same about it.
See how you went from using an amp for argument to a block? Just thought I'd point that out 🤗
If it's the terminal block that makes the number of outputs as you and Thx believe, then the mono amp behind that terminal block is irrelevant, no?
Or is it the "internal bridging" that is the real crux of it?
Th
That’s called “parallel wiring”.
“Bridging” in regards to a multichannel amplifier is as far from parallel wiring as you can get.
Do you think the terms are the same?
You didn't use the term "bridging" in your dumb-dumb post. You can play word games all you want, but literally everyone else who replied to that thread understood the question, so you're either dumb or socially awkward. Which is it?
Another stroke seizure coma? Been over 2 weeks and his family selfishly fled to canada and leaving him alone in the hospital.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
