Windows Media Player Lossless Bassmix
Its confusing, it took me awhile to see it, but do you see where there is a blank box towards the top right? It should say enter code here, then you click download.
Edit - I really don't know much about lossless, do I need a certain program to burn it? Will Itunes work? I'm on OS x
What code am I supposed to enter? I dont see it anywhere on this thread? Or I am not supposed to enter any code hah?
I extracted the song and whatever, it is perfect, the only problem I have is how do I add them to my itunes library? I have a mac so I dont have WMP? Is there any way to make them compatible with itunes?
No, it looks like that's the way it probably came on the CD. It's mild and tied to the quick "punch"style bass hits usually around the 50-60hz range. I only noticed it on two songs, "Boy Looka Here" and "In him".
I use Audacity but it doesn't play well with VBR files.
For clipping, I watch the song through a scope. You can also get a good idea of the frequency if you set the window correctly. The way I have it set up allows a full "standing wave" at 60hz and you can see a non-moving wave at the octaves above and below and at certain increments between. That gives me a good idea about where the bass notes are. If it's at 30hz or close to it, the 1/2 wave will either be not moving or it will move very slowly across the screen. If it's around 60hz, I'll see one full cycle or almost one moving very slowly. This also will occur at 45hz.
im not sure if i burned it wrong or something, but none of these songs hit at all, and the vocals are actually really quiet too? i tried my system and my friends, and we both had the same problem, the radio even bumps more- what the hell??
JCivicHb
JCivicHb
Denver
JCivicHb
