Wind noise
My Maserati makes a lot of aerodynamic noise. Guess I'll have to upgrade to a Lamborghini like Paris Hilton. In outer space there is no aerodynamic noise even while traveling at 16K mph - astronauts have perfect music up there.
Wind noise coming from the windows of a vehicle while driving has to be one of the most annoying noise IMO. How do you guys quiet or stop the noise in you own vehicle?
What kinda of vehicle do you have? Usually you have to just bend the top of the door back using a little muscle. Roll the window down all the way, position yourself on the inside of the door, place your knee on the inside door panel, pull top of door frame (usually at the rear corner) towards yourself. Test drive, if still not good enough do it again. Make sure you put your windows down all the way!!!!
This does help, if you want to try it. Just have to try a little and see if it helped or not. Just trying to help, or you could buy a new car as was suggested otherwise! HAHA.
Some of the wind noise you may be hearing is in the door itself. Air does travel through the door as you drive. As you are driving, lower the passenger side window and you will feel air entering someone on the driver door. Normally it is around the door handle.
Could be an issue with your seal surrounding the window. Some earlier vehicles had poor window setups and the window would actually not go into the seal at the top properly, or the window would not be perfectly level and would not line up on the side seals properly. checking to make sure the window goes all the way into the seals as it is rolled up may help other than that there is always fresh air intake spots in the vehicle, just simply wave your hand as you are driving and try to pin point the location the wind is blowing onto your hand.....woulda thought that would be common sense though. As for stopping it, well anything that blocks wind put around the area.
It's an Isuzu I-280 ext. cab
Simple, get used to it.
It's a truck; if you wanted quiet, you bought the wrong kind of vehicle.
BNolan12
BNolan12
Lafayette, LA
Spider Monkey
