Ive never used this antenna, except when I put it on my Go cart to see how well it works and it got out pretty far without me tuning it at all and I never drove the go cart with it on. I attached it to my trailer that sat in my backyard over the past summer and I took it off in August. It is white and has the 22" shaft. It was a little over $80 after taxes. I bought a mirror bracket that is meant for a semi (but you can mount it on other things) for $10 , and 50ft of cable that is in great condition for $30.
Here is some info on it...
Uses Silver Plated 10 gauge, Solid Copper Wire outperforms copper, nickel, & chrome plating Easily Handles 3,500 Watts Large coil housing for increased power handling Exclusive low loss coil design (Patent #4,882,591) Made From High Impact Engineering Thermoplastics Frequency Range: 26 MHz to 30 MHz, 7-7 spring stainless steel whip Can be used as a single antenna or co-phased for dual antennas 3/8" X 24" Standard Threaded Shaft 22" shaft
I'll also give you a Cobra CB radio but I dont know if it works.
Im looking to get $65 + shipping for it from 48135
