will u hear a differance in a 9512g and 9512e
i have called DD and talked to them about this topic when i traded my gmotor for an f motor. They said that you shouldn't be able to hear a big difference at all. Main difference in motors is power handling and cooling.....
If this is a Daily driver then no problems, if you plan to compete then get the best motor for better results.
Hope this helped
William
If you are running them together, dont do a common chamber, tuning same, but make sure that you get the airspace right, the G motor is better than the E so it will take up more space. But to make sure i would call DD they can help you out.
ddaudio.com
fatboyracing
fatboyracing
Owensboro KY
fatboyracing
