will this work?
# Max power output @ 4 ohm 1 x 450W RMS power output @ 4 Ohm 1 x 220W
# Max power output @ 2 ohm 1 x 700w
# RMS power output @ 2 Ohm 1 x 350W
# MOSFET power supply
# Frequency response 20HZ- 250HZ
# signal to noise >103DB
# stereo separation 83DB
# RCA input Voltage 200mV-8v
# RCA input Impedance 20K ohms
# Load impedance 2-8 ohms
# crossover frequency 50 HZ-250HZ
# Bass level remote control Included
# Damping Factor 300
# Amp Dimensions ( H x W x L ) 2" x 10-1/4" x 11-7/8"
im lookin to buy it, im a newb at car audio, i already bought the sub, and im lookin to buy a cheap amp, im also going to try to build my own box and install everything to saved as much $$ as i can
Profile amps are very good budget amps... they do pretty close to their rated power
If you don't want to spend too much money profile is a good way to go.
How much are you buying it for? It is a decent budget amp, but we might be able to find a step up in the same price range.
ChrisC
ChrisC
Plano, Texas
ChrisC
