will this amp work??
so, you have the amp. But, not the subs yet?
The amp should be alright. But they can take much more than 300wrms each.
If you cant afford a new amp. Then go with the SVC4 subs and wire them for a 2 ohm load
I would buy the dvc4 sub and get a 1ohm stable amp. Then wire the speakers this way
The subs should be good for around 600-900wrms of clean power each.
your info is very much appreciated. i'll do some thinking on the amp situation...if i do switch amps, i'll do like you said, get the dvc4 subs and drop it down to 1 ohm.
can you recommend a good amp, stable at 1ohm, and won't break the bank??
RUGERJITSU
RUGERJITSU
Tejas
RUGERJITSU
