will aipine 200 deck work the 701 prosecor
Yes, it will work. Great combo. Did you flip the switch on the deck from "norm" to "eq"? What connections are you using?
When in doubt, use your manuals.
thanks for your reply..yes i have fliped the switch..i can unhook the rca ..powercable and i net cable and plug in my 205 and it works fine just cant make the 200 work...any ideas
If you are using the exact same connections, it has to be something in the settings. Go into every single menu setting and see if you can figure it out. The manuals are golden. If all else fails, call Alpine support. They are usually pretty helpful.
thanks ...yea theres nothing in the manual that has helped ..we cant realy find anything other than the switch on the bottom...we can set the x-overs and such with the 200 hooked up but no sound ...i guess ill call tec...i dont have the number maybe its in the manual...thanks again
ally2dextreme
ally2dextreme
salisbury nc
lashlee
