Will (1) D3100 get me by?
i think my might need a lil more then that, im running 3000 watts at 1ohm and i got a mean green alt and a red top and still have really bad voltage drop
Hmmmm....
Do I have to run two of the same model?
Like, could I run (1) D3100 & (1) D1200 in the back & stock under the hood w/ an isolator? I think that should be sufficient, do yall?
yeah i'd be running 2 agm batteries if i were you, plus the charging upgrades. one battery on that much power is asking a lot, unless you're only going loud for very short periods.
Well, you're running a yellow top & a d3100 w/ a lil less watts to power than me. How's it doing for you? I might go that route.
I'd go with 1 d3100, two if possible. d3100's can support 3.5-4kw from what I've seen, but obviously your putting out a bit more then that, so two would be ideal. If you cannot budget two PM D3100's, go for a D3100 and a smaller PM AGM batt, maybe the 2700 or 2400 or something.
c0smo kram3r
c0smo kram3r
Alabama
c0smo kram3r
