So I had an Alpine 9883. Hooked up an Eclipse 4 channel EA4200 to it wired to the speakers at 4 ohms and an Alpine MRP M500 for my sub, also wired to the sub at 4 ohms. When I checked the gain with tones I found clipping set in on the Alpine at 29 out of 35. I set the Eclipse 4 channel gain by ear using tones and a throwaway speaker then double checked with a DMM. Both front and rear gain dials ended up almost precisely at the 2 volt mark to match my HU's rated voltage output.
I set the sub by ear and double checked with a DMM. Ended up at a tad below .5 volts out of an input sensitivity range of .2-4 volts on the gain dial.
Changed head units to a 4 volt radio and added Hertz speakers to replace my eclipses, then bridged the amp to the HErtz HSK 165s. Re-checked gains again. The eclipse seemed to end up perfect at almost exactly 4 volts. The Alpine, I re tuned by ear to listen for distortion at 28-30 and to ensure it increased sub volume in as linnear of a manner as the mid/high amp. Then today I just double checked multiple times with a DMM. At a volume level of 27 out of 35 with a 50 HZ 0 DB test tone, I'm getting the proper voltage on the meter and everything sounds perfect but the notch is only barely above the .5 volt mark and still not at the half-way point between .2 and 4 full volts. Measurements are taken with EQ flat, crossovers on full, and Sub volume on 15 at the head unit.
Im just curious as to other's opinions on why the gain settings on the Alpine keep ending up so far off from the markings on the dial: Could this be attributable to the amp's gain dial markings being way off, could the sub pre-amp out be putting out significantly less voltage than the rest of the HU outputs, or could there be some sort of problem in the wiring preventing my amp from receiving the proper voltage from the head unit? It sounds perfect and I'm not inclined to mess with it unless someone in the know thinks it signifies some sort of problem that should be diagnosed. Maybe if people could tell me where their gain dial is set by the markings and where it ended up using textbook tuning techniques it would help.
It's been like this through a 2 volt and a 4 volt HU so Im inclined to believe it's either a normal quirk for this amp or else a problem with it or its wiring.
